        查看: 6789|回復(fù): 0
        賬號(hào)的QQ無(wú)法綁定的解決辦法
        haotengtech 發(fā)表于 2015-12-30 17:21:31 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
        Discuz! Database Error(1054) Unknown column 'conuintoken' in 'field list'INSERT INTO common_member_connect SET `uid`='1' , `conuin`='' , `conuintoken`='F3758922C1FB341D8CD831880914D51E' , `conopenid`='920D025C572EE15924908CC55DA66B53' , `conispublishfeed`='0' , `conispublisht`='0' , `conisregister`='0' , `conisfeed`='1' , `conisqqshow`='0'
        No.FileLineCode
        1connect.php40require_once(%s)
        2source/plugin/qqconnect/connect/connect_login.php226discuz_table->insert(Array)
        3source/class/discuz/discuz_table.php81discuz_database::insert(%s, Array, false, false, false)
        4source/class/discuz/discuz_database.php60discuz_database::query(%s, %s, %s, true)
        5source/class/discuz/discuz_database.php136db_driver_mysql->query(%s, %s, true)
        6source/class/db/db_driver_mysql.php153db_driver_mysql->halt(%s, %d, %s)
        7source/class/db/db_driver_mysql.php224break()
        1、修改config/config_global.php文件查找下面代碼把0改為1
        $_config['admincp']['runquery'] = '0';改成$_config['admincp']['runquery'] = '1';
        2、打開(kāi)后臺(tái)-站長(zhǎng)-數(shù)據(jù)庫(kù)-升級(jí)
        在打開(kāi)的數(shù)據(jù)庫(kù)升級(jí)語(yǔ)言框里輸入2樓的2句升級(jí)語(yǔ)言
        復(fù)制語(yǔ)言進(jìn)去點(diǎn)提交
        ①、 ALTER TABLE  `pre_common_member_connect` ADD COLUMN conuintoken char(32) NOT NULL DEFAULT '';
        ②、ALTER TABLE  `pre_common_connect_guest` ADD COLUMN conuintoken char(32) NOT NULL DEFAULT '';
        該會(huì)員沒(méi)有填寫(xiě)今日想說(shuō)內(nèi)容.
